Problem with Kufatec BI-Xenon on Golf VI
    • Problem with Kufatec BI-Xenon on Golf VI
      With GOOGLE TRANSLATE
      Hallo Alle.
      Ich habe das Kufatec BI-Xenon Kit inkl. Adapter auf meinem Golf VI mit originale Xenon-Scheinwerfer installiert. Aber ich kann sie nicht mit Fernlicht Licht auf die Xenon-Scheinwerfer funktionieren. Sie sind auf Abblendlicht (normale Licht) die ganze Zeit arbeiten??
      Wer weiß, was kann das liegen?
      Mit freundlichen Grüßen Ulrik
      ENGLISH.:
      Hallo All.
      I have installed the Kufatec BI-Xenon kit incl adapters on my Golf VI with originale Xenon headlights. But i can´t get it to work with HIGH beam light on the Xenon headlights. They are working on LOW beam (normale light) all the time ???
      Does anyone know what can be wrong ?
      Best regards Ulrik
      Golf VI 1.6 TDI 105 BlueMotion Technologies DSG-7 Highline, DK-Paket, Winter-Paket, Spiegel-Paket, Einparkhilfe, Fernlichtassistent, Reserverad 16 "Alu, Extra Gassackpaket hinten, Multifunktions-w / Shift-Funktion, um DSG, Schirk-Paket, Technik-Paket, Großer Alarm-Paket , Xenon-Scheinwerfer mit LED TFL, AFS aWLR, LED-Rückleuchten, GTI Heckspoiler, Zenec 2010 Navigation, 30 mm abgesenkt.
    • Hello udsulle,
      perhaps the coding of your controller 55: headlamp range adjustment is wrong. What coding do you have there? What is the part no.? 5M0 907 357 C?
      And do you have DCC, RainLightSensor or 4motion?
      Gruß Linx,
    • Hallo Linx
      Sorry but i´m a newbee - so you have to excuse me :)
      I cant get the HIGH beam and the lights to turn / up / down`?
      My car have Light Assistens - can it be that ?
      Today i called Kufatec hotline becurse the wireset from Kufatec there was a Pin 1 + Pin 2 + Pin 4 (But my PIN 4 was taken in the Kufatec adapter) So Kufatec says that i just have to leve it be ?? But i´ts a black wire who has connection to the fuse box - I think perhaps the problem is there ??
      So buttom line.... On both my headlights i only have two out off tree wires connected to my Kufatec adapters.
      Here is my VCDS list from the car.:
      Tuesday,16,November,2010,19:48:11:46862
      VCDS Version: Beta 912.0
      Data version: 20091201
      Chassis Type: 7N0
      Scan: 01 02 03 08 09 10 15 16 17 19 20 25 42 44 46 52 56 61 62 72
      VIN: WVWZZZ1KZBP076857
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: Malfunction 0010
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      10-Park/Steer Assist -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      16-Steering wheel -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: Malfunction 0010
      20-High Beam Assist. -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      61-Battery Regul. -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      Address 01: Engine (J623-CAYC) Labels: None
      Part No SW: 03L 906 023 DR HW: 03L 906 023 A
      Component: 1,6l R4 CR td H23 6917
      Revision: -------- Serial number: 00000000000000
      Coding: 00254036032401080000
      Shop #: WSC 00028 028 00302
      ASAM Dataset: EV_ECM16TDI02103L906023DR 003007
      ROD: EV_ECM16TDI02103L906023DR.rod
      No fault code found.
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: None
      Part No SW: 0AM 300 049 K HW: 0AM 927 769 D
      Component: GSG DSG AG7 403 2101
      Revision: 00040034 Serial number: 00001010126102
      Coding: 0000020
      Shop #: WSC 00028 028 00001
      1 Fault Found:
      006299 - Clutch 2: Clearance too Small
      P189B - 000 - - - Intermittent
      Freeze Frame:
      Fault Status: 00100000
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 10
      Mileage: 187 km
      Time Indication: 0
      Date: 2000.14.14
      Time: 17:18:20
      Address 03: ABS Brakes (J104) Labels: None
      Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
      Component: ESP MK60EC1 H31 0108
      Revision: 00H31001
      Coding: 113B200D09290000881304E990200051350000
      Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
      Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
      Component: Climatronic H15 0709
      Revision: 00003001
      Coding: 0000000003
      ASAM Dataset: EV_Climatronic A01006
      ROD: EV_Climatronic_VW36.rod
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
      Component: BCM PQ35 M 103 0615
      Revision: 00103 AD
      Coding: 40180A3A8825F3C040080088740081E443510088636D8560648087200041
      Part No: 1K1 955 119 F
      Component: Wischer 06101 26 0512
      Coding: 009795
      Part No: 1K0 955 559 AH
      Component: RLS 191010 05 54 0403
      Coding: 0330AD
      Part No: 1K8 951 171
      Component: DWA-Sensor 00 001 0104
      Part No: 1K8 951 605 A
      Component: LIN BACKUP HO H11 9004
      7 Faults Found:
      00987 - Lamp for Brake Light; Left (M9)
      010 - Open or Short to Plus - Intermittent
      Freeze Frame:
      Fault Status: 00101010
      Fault Priority: 1
      Fault Frequency: 14
      Reset counter: 44
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 19:47:42
      Freeze Frame:
      Term 15 Off
      Voltage: 12.60 V
      OFF
      ON
      Term 50 Off
      OFF
      OFF
      00988 - Lamp for Brake Light; Right (M10)
      Freeze Frame:
      Fault Status: 01101010
      Fault Priority: 1
      Fault Frequency: 14
      Reset counter: 4
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 19:58:31
      Freeze Frame:
      Term 15 On
      Voltage: 12.35 V
      ON
      ON
      Term 50 On
      OFF
      OFF
      01502 - Bulb for Rear Fog; Left (L46)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 42
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 20:21:36
      Freeze Frame:
      Term 15 On
      Voltage: 12.30 V
      ON
      ON
      Term 50 On
      OFF
      OFF
      00984 - Left Tail Light (M4)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 13
      Reset counter: 4
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 20:17:26
      Freeze Frame:
      Term 15 On
      Voltage: 12.35 V
      ON
      ON
      Term 50 On
      OFF
      OFF
      00985 - Right Tail Light (M2)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 13
      Reset counter: 4
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 20:17:26
      Freeze Frame:
      Term 15 On
      Voltage: 12.35 V
      ON
      ON
      Term 50 On
      OFF
      OFF
      01504 - Bulb for License-Plate Light (X)
      014 - Defective - Intermittent
      Freeze Frame:
      Fault Status: 00101110
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 42
      Mileage: 70 km
      Time Indication: 0
      Date: 2000.14.13
      Time: 20:20:16
      Freeze Frame:
      Term 15 On
      Voltage: 12.40 V
      ON
      ON
      Term 50 On
      OFF
      OFF
      012 - Electrical Fault in Circuit
      Freeze Frame:
      Fault Status: 01101100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 4
      Mileage: 276 km
      Time Indication: 0
      Date: 2000.14.14
      Time: 19:43:09
      Freeze Frame:
      Term 15 On
      Voltage: 12.35 V
      ON
      ON
      Term 50 On
      OFF
      OFF
    • Before an "Auto-Scan", you have to choose the right chassis type. Golf VI should be 1K0 or 5K0, but not 7N0. Can you additionally install VCDS 10.6 instead your beta?
      In the list with the control modules, i miss no. 55. This is the modul for adjusting the headlight range automatically. With xenon, your old adjustment wheel from your halogen head lights should not work anymore.
      I can't help you in details with wiring, because i have not retrofittet xenon in any car yet, and my golf does not have xenon headlights. Perhaps it is a wiring problem, or a missing control module (55).
      Did you install a level sensor at your rear axle?
      Gruß Linx,
    • Hi Linx and RustyCS
      Yes I did install a level sensor at the rear axle.
      All installations is done from Kufatec guide.
      Only problem I ran into, is that there is a black wire at both headlights from Kufatec wireset i dont need to use (what Kufatec says) So im a little worry
      My car have Light Assistance - can i be that who course the problems ?? I dont know ?
      We must see. Perhaps I take a trip to Kufatec in DE so they can fix my problems.
      I keep you posted :)
      Thanks
      Best regards Ulrik
    • Hi, udsulle!
      Some months ago, i retrofitted the same on my Golf MK6 (2009!! WITHOUT Light Assistance )
      I used the "Xenon-Adapters-Wireset" and the "Auto-Leveling-Wire-Set".
      I don't know which Cabels du you mean ...
      The headlight adapters are connected between the harness in the car and the headlights. On these adapters are 2 cabels witch you hate to plug in in the BCM-Controller [Adress 09] (linke in the install-guide). <-- These are for the High-Beam / Shutter
      The autoleveling-Wireset have to be connected with the levelingsensor, with the Autoleveling-Controller [Adress 55], 1 cable with ground, 1 cable with ignition plus (clamp 15), 2 cables with CAN Low and CAN High and last but not least 1 calbe to the left headlight and the other to the right headlight. (linke in the install-guide)
      I hope my post will help you to find the fault.
      Good Luck!
      EDIT: Are you sure, that your BCM Supports BI-Xenon?
      I used the 1K0 937 087E
    • Hey Rexos ...
      Frage zum BCM
      Original ist das normale Highline (Modellvariente, weil das ja anscheinend auch ne BCM-bezeichnung ist) BCM.
      MJ 09, Xenon war damals noch nicht lieferbar.
      Habe jetzt Xenons daheim, +Adapter usw. , Golf R Led´s hinten und ne GTI Front (mach mir gedanken wegen den Neblern)
      Wäre es doch logisch, ein BCM von nem GTI MJ 2011 zu nehmen, weil diese sowhl Xenon als auch die LED´s ab werk lieferbar haben.
      Oder was meinst du, welches hast du z.b. verbaut?
      Grüße, Christoph !
    • Genau das hab ich gemeint.
      Also gehts um die Grundeinstufung des BCM´s
      und das Highline + unterstütz quasi alles oben genannte ?
      LED Rülis, Xenon usw .... wie ist das mit dem Abbiegelicht, daher kam ich auf das GTI BCM, weil angeblich sollen die GTI Nebler ja nicht als Abbiegelicht zugelassen sein.
      Somit würde dann unnötiges rumprogramieren wegfallen !??!
      THX erstmal Jungs !
    • Hi rexos!
      On the adapters from Kufatec - You must set PIN 1 and PIN 2 (they are gray color) and PIN4 (Black) But on my adapters from Kufatec the PIN4 is already taken ???
      Just today i went into all the installations again, just to check that i have done i correct. It is when im using the guide from Kufatec.
      But still !!!! I cant get HIGH beam and turn up/down Side to Sid on my headlights ???
      It seem that im missing som power on the headlights to get them working wint HIGH beam.
      Did you go into your fuse box with a black or purple wire ??
      I have a Black wire (dobble wire) from the fuse box up to both headlights - it meaning that the black goes to PIN4 but kufatec says that i dont need it ???
      Hope you can help :)
      Perhaps i can email you all my VCDS spec?
      Best regards Ulrik
    • Golf VI 1.6 TDI 105 BlueMotion Technologies DSG-7 Highline, DK-Paket, Winter-Paket, Spiegel-Paket, Einparkhilfe, Fernlichtassistent, Reserverad 16 "Alu, Extra Gassackpaket hinten, Multifunktions-w / Shift-Funktion, um DSG, Schirk-Paket, Technik-Paket, Großer Alarm-Paket , Xenon-Scheinwerfer mit LED TFL, AFS aWLR, LED-Rückleuchten, GTI Heckspoiler, Zenec 2010 Navigation, 30 mm abgesenkt.
