How to program LED tail lights on Golf VI
    • How to program LED tail lights on Golf VI
      GOOGLE TRANSLATE.:
      Hallo alle.
      Aber wie kann ich ihnen Programm zu löschen das Licht in der Platte nicht - ich habe die LED-Rückleuchten mit KUFATEC Adapter auf meinem Golf VI 11/2011 installiert.
      Die Rückleuchten funktioniert gut - alles OK, aber Ich mag die Lampe Fehler im Armaturenbrett / Dashboard töten
      ENGLISH.:
      Hallo all.
      I have installed the LED tail lights with kufatec adapters on my Golf VI 11/2011 - but how can i program them to erase the light fail in the panel.
      The tail lights works fine - all OK, but i like to kill the lamp error in the Armaturenbrett / Dashboard
      My info´is.:
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
      Component: BCM PQ35 M 103 0615
      Best regards Ulrik
      Golf VI 1.6 TDI 105 BlueMotion Technologies DSG-7 Highline, DK-Paket, Winter-Paket, Spiegel-Paket, Einparkhilfe, Fernlichtassistent, Reserverad 16 "Alu, Extra Gassackpaket hinten, Multifunktions-w / Shift-Funktion, um DSG, Schirk-Paket, Technik-Paket, Großer Alarm-Paket , Xenon-Scheinwerfer mit LED TFL, AFS aWLR, LED-Rückleuchten, GTI Heckspoiler, Zenec 2010 Navigation, 30 mm abgesenkt.
    • Hi usdulle,
      i can see that your car is model year 2011. Can you code your byte 18 to 43? If this does not work, try byte 18=15, but i think 43 should be right. 15 is for halogen, 43 is for xenon headlights.
      kind regards,
      Gruß Linx,
    • Hi Linx
      Ok, i understand you - but when i go into BYTE 18 i get a warning mess. that says.... "the if any data is change - it can´t be change back again" so i´m a little worry to do that :S
      Is i right that to go into that ?
      Thanks.
      Best regards Ulrik
    • Hi Linx
      I will try to upgrade to 10.6 and goe into the byte 18 and use 43 = Xenon
      So we see if it works on my car :)
      Thanks
      BR
      Ulrik
