Problem with tail light after replaching BCM unit.
    • Problem with tail light after replaching BCM unit.
      Hello
      After replacing BCM box on my friend's Golf 2010 so that he can get high light on his xenon light, we now have another problem / challenge. The car has now only weakly backlight on - not off but weak .... as if it only gets half the power out to the taillights.
      I must remember to tell that this BCM box before have been sitting on my Golf which has LED taillights, but my frinds Golf only have Xenon headlights NOT LED tail lights. Could it be the reason?
      The BCM unit No. 1K0 937 087 E
      Thank you :)
      Gruss Ulrik
      Golf VI 1.6 TDI 105 BlueMotion Technologies DSG-7 Highline, DK-Paket, Winter-Paket, Spiegel-Paket, Einparkhilfe, Fernlichtassistent, Reserverad 16 "Alu, Extra Gassackpaket hinten, Multifunktions-w / Shift-Funktion, um DSG, Schirk-Paket, Technik-Paket, Großer Alarm-Paket , Xenon-Scheinwerfer mit LED TFL, AFS aWLR, LED-Rückleuchten, GTI Heckspoiler, Zenec 2010 Navigation, 30 mm abgesenkt.
    • Your friend has a Golf with Xenon, and he retrofitted the VW LED taillights and your BCM 1K0 937 087 E with SW 0575?
      Have you copied the complete coding of the old BCM? Or have you chanced anything?
      Gruß Linx,
    • He retofitted Xenon headlights - but have the standard Halogen tail lights (Not LED tail lights)
      Yes we have copied the old coding from his first BCM unit on to the new unit.
    • Linx schrieb:
      Then try to reset Byte 18! (Coding C0 and then 00)
      Nice :) I try to reset byte 18!
      Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von Linx ()
