Suspension on Golf 6 GTI and BlueMotion
    • Suspension on Golf 6 GTI and BlueMotion
      Hello.
      Is there anyone who knows how much a Golf GTI and the Golf BlueMotion is lowered from the factory?
      Is it 30mm compared to a standard Golf 6?
      Thanks
      Ulrik
      Golf VI 1.6 TDI 105 BlueMotion Technologies DSG-7 Highline, DK-Paket, Winter-Paket, Spiegel-Paket, Einparkhilfe, Fernlichtassistent, Reserverad 16 "Alu, Extra Gassackpaket hinten, Multifunktions-w / Shift-Funktion, um DSG, Schirk-Paket, Technik-Paket, Großer Alarm-Paket , Xenon-Scheinwerfer mit LED TFL, AFS aWLR, LED-Rückleuchten, GTI Heckspoiler, Zenec 2010 Navigation, 30 mm abgesenkt.
    • Okay, can you tell me what part no i most use to the GTI springs ?
      Can it be,; 1K0 411 105 JT ?
      I found a color code.: Yellow - White - Yellow
      But how do I know if they fit on my Golf BMT with DSG7 ??
      I only like to get springs that lower the car appox, 1,5 or MAX 2 CM !!
      Thanks
      Ulrik
      paffi schrieb:
      @ss: no, only in the back.
      GTI mk 6:
      front: 22mm, back 15mm.
      bluemotion: i dunno.
      Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von udsulle ()
    • paffi schrieb:
      part no. is 1TO 413 031 EQ ( front) & 1KO 512 011 MM ( back).
      i used google for it but I can check it and take some pics when i'm back at home if you want me to.
      Hi Paffi.
      YES!!! Many thanks !
      I like to see the pic. and also can you give me the lengths from the road surface to the fender (Kotflügel) "If you have your orignale wheels on your car" :)
      Regards Ulrik
    • i have the original rims on my car right now (18" detroit), but I have already switched over to a kw v1. inox.
      the original suspension is stored in my cellar @home, so a picture of suspensions is easily done, but measuring distance from fender to road with the original one is a little bit hard ;);)
      Ohh yes! I see that is a bid hard for you to show me :)
      Anyway, I can see there is a lot of suspensions types to Golf GTI (lot of color and no. )
      So what can i do to get the right set for my Golf?
      Is i just to jump on the same as you have from factory or ??
      Thanks
      Regards Ulrik
    • I would recommend you sport springs from Eibach or H&R, or a good coil-over!
      The weight of your engine, and so the axle load, differs from the axle load of the GTI. You will not get the same lowness.
      Gruß Linx,
      I already have the Pro springs form Eibach, but i´m 30 mm low, and in my driveway the car goes on a bump + a lot of other places.
      So i need some more "hight" on my car. So just between standard Golf and the 30mm
      20 mm i will be happy!
      Gruss
    • paffi schrieb:
      there you go:
      front:
      rear:
      Thanks - i´ll look into if it matters on my Golf with this suspensions.
      Gruss
      Ulrik
