Hello, here is the problem: I have g5 tdi 2005, and bought
power window module with lifter, and wiring in the door from g5 2008.
The control modules are the same in the front door, but I have an issue
with the wiring. As far I was googling, I found the old wiring diagrams,
probably they changed the shemas. There is a plum/white wire on Pin 6
at the door 28 pin A-pillar and B-pillar connector, that is the same
wire in drivers TürStg 20pin 15th pin, and rear door 18pin 12th pin.Is it connected directly from the drivers door to the passenger door and the rear doors? All the TürStg modules are comucating by the plum/white wire?
Pin 1 ro/ge = Plus Klemme 30
Pin 4 or/gn = can low
Pin 5 or/br = can high
Pin 6 li/ws = zu TürStg. Fahrerseite hinten
Pin 11 ws = zu TürStg. Fahrerseite
Pin 12 ro = Airbag Crashsensor
Pin 13 br = Airbag Crashsensor
Pin 21 br = Masse
Pin 22 ro/ge = Plus Klemme 30
Pin 23 ro/bl = Lautsprecher + (Bei Weiche in der Tür)
Pin 24 br/bl = Lautsprecher - (Bei Weiche in der Tür)
Thank you very much! [Blockierte Grafik: http://www.klangfuzzis.de/images/smilies/grins.gif]
