How can i reset the throttle valve?
    • How can i reset the throttle valve?
      In a site i have read that after the clean or a dismantle of the throttle
      valve body i must reset the setting of that part.
      Do u know the correct procedure?
      Must i use the VAG to do this?
      Thanks in advance
      Fred (IT)
    • RE: How can i reset the throttle valve?
      VAG-COM is the best way for resetting the throttle body, but it also can be done without it. Disconnect your battery for 5 min., reconnect it and leave the ignition on for about five minutes; you'll hear the different valves going through all positions. After that let the engine idle for another five minutes and then go for a testdrive- try to simulate all possible driving situations from low rpm to high rpm. The throttle valve/body has to learn the different positions by this procedure.
      With VAG-COM the hole thing takes just a few minutes; IMHO the nicer way to do it. ;)
      Gruß Olli,
      GTI 1.8T since '02
      family car: Golf VII GTI
