ZitatAlles anzeigenThe driver’s side:
[Blockierte Grafik: http://web.utk.edu/~sboada/drisidebolt.jpg]
The driver’s side is a little more complicated. Make sure to remove the tail light bulbs. Unbolt the two bolts (in pink) that connect the taillight to the car. These are two of the three bolts that hold the tail light in place. These two bolts are 8mm. Be careful not to drop them down inside of the car. Once this is done, you will have to do a little work to remove the third bolt.
[Blockierte Grafik: http://web.utk.edu/~sboada/drisideinside.jpg]
The first thing that you need to do is to remove the CD changer holder. Remove the 5 bolts (circled in yellow). They are all 10mm. I used a wrench to remove bolt number 5 because it was a tight fit with the ratchet and extender. Once you have removed the CD holder, peel back the carpet. Be careful to not rip the carpet. It is help into place by a plastic rivet. Remove that and peel the carpet to expose the body of the car. Once this is done, you will see some wires and a square cut out in the body of the car.
[Blockierte Grafik: http://web.utk.edu/~sboada/thirdbolt.jpg]
This is where the third bolt is located. Everyone stresses that you do not want to drop the bolt down inside of the car. This is true, you don’t. If you do, it is OK just reach down in there and get it. It does make things a little harder if you do drop it though. To prevent from dropping it, many people suggest the “sticky nut” idea. This involves using some gum to stick the nut to the end of your socket. I didn’t have any gum, so I used some toothpaste. It worked very well. Use tools number 9 and 3, along with some toothpaste, and fish around inside of that hole until you can loosen the bolt. Remove the taillight just as you did on the passenger side. To avoid dropping the nut, I just left my screwdriver in the hole. I didn’t want to risk pulling it out and dropping the nut. Once the new taillight was in place I just fished around until I lined the two up once more. It was easy. Once you have the new taillight bolted in, just put everything back together the same way you took it apart. There should be nothing left over. Don’t forget to put the black foam-rubber thing on your new tails if you need it. It is a pain to remove it all again. If you have any questions or problems with this DIY, feel free to pm me. Total work time is about an hour, assuming nothing goes wrong.
The finished product:
[Blockierte Grafik: http://web.utk.edu/~sboada/finished.jpg]
~z000m
Modified by Z000M at 11:49 PM 6-7-2005
Rückleuchten
nice DANKE!
haste die celis schon bestellt??
nein, noch nicht
werde die wahrscheinlich gebraucht kaufen!
Zitat
Original von JO-18 Golf IV
Hab mal ne Frage zu den "In.Pro Celis".
Wie sieht es bei denen mit der Passgenauigkeit aus? Sind alle, auch die bei den Ebay-Auktionen von dem gleichen Hersteller?Neue Rückleuchten sind eintragungsfrei, oder?
Die Celis gibt es nur von einem Hersteller!
Wie soll es mit der Passgenauigkeit denn ausschaun?In.Pro ist was Leuchten angeht genauso ne Top-Marke wie Hella und Hella fertigt schließlich auch die Serienleuchten!Und ja,sie sind eintragungsfrei!
Ich hole mir demnächst für keinen G auch die Celis oder die r-w-r.Kann die silbernen In-Pro die ich drauf hab nicht mehr sehen.
die für 100€ hier ausm forum?
Zitat
Original von SharpShooter
die in.pro celis sind eintragungsfrei
das gilt aber nicht für jede neue rückleuchte -
ja, ich muss mal gucken^^
können die dann ja zusammen einbauen *lol* -
kommt hier eigl noch wer aus osnabrück?
irgendwer aus bramsche mit nem g3 cabrio im g4 look is noch hier
aber sonst kenn ich keinenkönnen wir vielleicht machen
will die mal in natura sehen -
Zitat
Original von _G-DoG_
das gilt aber nicht für jede neue rückleuchteDas gilt schon für eigentlich jede Rückleuchte sofern sie nicht lasiert ist!Bzw. es gibt für den G4 keine einzige Rückleuchte am Markt die man eintragen lassen muß.
an sich ja
meinte das auch nur weil man bei ebay ja nie weiß -
dann können wa gleich alles zusammen anbauen...hab bis dahin gfw,felgen und alle so nen kleinskrams
warte mal noch ein wenig
bald hab ich 6 wochen sommerferien
wird zwar knapp, aber mit glück schaffen wir das in der zeit -
das alles einzubauen? dauert doch nicht 6 wochen^^
